Fuel Regulator part number and replacement process?
1997 FORD TAURUS
180,000 MILES • V8 • 2WD • AUTOMATIC
SBEIMERT1
I have a 97 Ford Taurus SHO. The car would start but a couple seconds or so later it would stall out. We were told it was the fuel regulator. We tried one from a different year Taurus and it wasn't a SHO. Does that matter?
Oct 17, 2009 at 8:17 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the information you requested. To answer your question yes, you cannot use a different year or engine size fuel pressure regulator. After replacing the fuel pressure regulator with the correct one I suggest performing a fuel pressure test. Here is a tutorial showing how to perform a fuel pressure test:
I've attached picture steps below on how to replace the fuel pressure regulator on your car. I've also attached a picture below showing the correct fuel pressure specification for your car if you decide to perform a fuel pressure test when the repair is completed and the correct factory Ford part number for the fuel pressure regulator. Hope this helps and thanks for using 2CarPros.
Jul 15, 2021 at 7:54 PM
