1996 Ford Taurus Compressor not kicking in
1996 FORD TAURUS
139,000 MILES • 6 CYL • FWD • AUTOMATIC
I have read the other discussion on this issue; However, I don't have power to the purple wire. where could the fuse or relays be located?
Apr 22, 2009 at 5:01 PM
BMRFIXIT
  • 19,053 POSTS
Constant control relay module is located behind left headlight lamp
check AC cycle pressure switch at right front of engine compartment
fuse # 13 and 6 under driver side fuse panel
check and make sure system full
Apr 22, 2009 at 8:31 PM
Thank you for your response, I have now found out the system is leaking. From the compressor and a hose is where its leaking. 900 dollars, Uh I don't think so. Time for new car. :)
May 6, 2009 at 3:49 PM
BMRFIXIT
  • 19,053 POSTS
Ouch !!
many ,many deals out there
you should shop around
wish you best of luck
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
May 6, 2009 at 8:42 PM
