1996 Ford Taurus codes
1996 FORD TAURUS
PISSEDINAK
Computer problem
1996 Ford Taurus 6 cyl Front Wheel Drive Automatic
i have a p1000 code. how do you get this code out of computer? no other codes are present.
Jan 28, 2010 at 8:22 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating!
You must use a diagnostic scanner to reset the trouble codes stored. DO NOT disconnect the battery to clear codes. This will erase opearting information from Keep-Alive Memory (KAM) and cause driveability problems.
Jan 28, 2010 at 9:03 PM
BMRFIXIT
  • 19,053 POSTS
Code p1000 is an information code and
is an indication that the battery was disconnected or the PCM was reset
and have not yet complete a driving cycle
the only way to clear that code is by driving and completing a drive cycle once to conditions met the code will clear itself
will not be able to get a sticker if have this code because monitor system is not ready
Jan 30, 2010 at 10:20 PM
