1996 Ford Taurus battery cable was loose change the cable g
1996 FORD TAURUS
139,000 MILES • 6 CYL • FWD • AUTOMATIC
PAPAWES
car wont start after did all the above
Dec 4, 2009 at 10:11 AM
MIKE H R
  • 3,094 POSTS
Usually a car wont crank because of a bad connection. Even though the cables may look good corrosion builds up inside. Take the cables off and clean them especially the ground. We used to use coke a cola and put that on to clean the terminals, but its better if they are manually cleaned. check the ground for a good connection on the engine.
Dec 4, 2009 at 12:22 PM
