1995 Ford Taurus No tail lights or dash lights
1995 FORD TAURUS
LAURELLANE
Electrical problem
1995 Ford Taurus Front Wheel Drive Automatic 160000 miles
I've recently lost power to my tail lights and
the dash. I still have brake lights, signal lights, headlights. I checked the fuses inside and out. what else should I do and do you have an estimate on what it might cost to fix?
Thank you,
Lights out in Texas
Dec 8, 2009 at 3:28 PM
JDL
  • 16,098 POSTS
Welcome to the forum, check fuse 15-- 10 amp, in interior fuse box, use testlite, that circuit goes hot when you turn on the headlamp switch. If that circuit isn't hot, check fuse 4-- 20 amp in same fuse box, should be hot all the time. Also, there is a headlamp fuse in the underhood fuse box, 60 amp I believe. Check for voltage on that fuse circuit also, hot all the time. Let us know what you find.
Could be a problem with headlamp switch?
Aug 6, 2019 at 5:13 PM
