1994 Ford Taurus leak detection
1994 FORD TAURUS
91,000 MILES • 6 CYL • 2WD • AUTOMATIC
KEGELMTA
  • 19 POSTS
Have a fairly serious fc134a leak in this vehicle but am having trouble pinpointing the exact location. I have a freon leak detector that goes off like crazy around the compressor which happens to be right by a quick connect for the high pressure line. I put refrigerant with UV leak detector in it and checked for leaks at the quik connect with black light. Didn't see any evidence of leaking around the quick connect. Saw a little bit of the UV stuff on the top of the compressor. My question is: Is it likely that the compressor is leaking refrigerant? I've done several AC repair jobs but haven't run into a leaking compressor. Usually the high pressure lines, connectors or condensors are more likely to leak.
May 12, 2010 at 1:33 PM
BMRFIXIT
  • 19,053 POSTS
we had compressor front seal leaks check around the clutch area
if have a smoke machine use it for a clear and better way to find the leak
i found it very easy to locate a leak using the smoke verse dye and black light
May 12, 2010 at 7:30 PM
KEGELMTA
  • 19 POSTS
I don't like the UV leak detection method either. Poor results and it makes a mess.
Is the smoke machine you're talking about something that you squeeze and small puffs of smoke come out of it? I've seen people use those to check fume hoods. I might be able to borrow one of those.
I don't have a smoke machine but I can think of two other alternatives if I can't borrow one. 1. I can put dry ice & H2O in a container, cap container with inverted funnel and put tubing over funnel outlet and aim at compressor. 2. I could try smoking a cigarette and blow the smoke out at the compressor but I doubt I could inhale the tobacco.
Thanks for the advice.
Tom
May 13, 2010 at 6:38 AM
BMRFIXIT
  • 19,053 POSTS
I've never tried or used what you mentioned
and i doubt it would work you need more controlled smoke
smoke machine becoming a very important diagnose helper can be used in many application
May 13, 2010 at 6:20 PM
