There is a control regulator mounted inside the driver door panel that buzzes, and will not allow the car to start. When you push on the window buttons it stops buzzing but still will not start. About 2 years ago the part was replaced and the car was fine until recently. Part was replaced again but did not fix the problem this time. The car has spark from the coil and module. Battery has been replaced along with the alternator also. What is making this module buzz and causing the car to not start or stall.
Oct 23, 2008 at 2:24 PM
