1994 Ford Taurus 1994 Ford Taurus electriacal problems with
1994 FORD TAURUS
189,000 MILES • 6 CYL • FWD • AUTOMATIC
MRYANHOCKEY87
My 1994 ford taurus has had a fuel problem in last couple of weeks; i replaced the fuel filter, checked the pump which was in good condition even though i have had a problem. i know its not the pump, the filter, i checked the IRCM model J and the pump work when i positve jump on the alternator and the pin for the fuel pump. Know my question is where is the fuel pump relay and the droping resistor; and the inerta switch i have checked but i cant find the problem their.
thanks
Aug 13, 2010 at 9:38 PM
Hi mryanhockey87, welcome to 2carpros and TY for the donation
What liter -3.0 or 3.8L ??
When you applied direct power to the fuel pump this will cause the engine to fire up unless the injectors are not pulsing or its not getting an ignition spark-
Although the new fuel pump comes on, the question here-is it producing the correct fuel pressure, you need to check the actual fuel pressue if its within specs
Aug 13, 2010 at 11:18 PM
MRYANHOCKEY87
thank you for your input.
know i also checked the resistance to the injectors and didnt give me a reading on two of them facing in front of the engine. also where is the relay? and if the pressure is a problem my option would be changing the regulator near the manifold, right?
Aug 14, 2010 at 9:07 AM
The fuel pump relay is integrated within the constant control relay module on upper radiator support. You need to check the fuel pressure with a gauge to rule out the fuel filter, fuel pressure regulator and fuel pump
Aug 14, 2010 at 2:44 PM
