1993 Ford Taurus windsheild wipers
1993 FORD TAURUS
165,000 MILES • 6 CYL • FWD • AUTOMATIC
GRUMPYNETTA
  • 4 POSTS
my wipers dont wsork and we tried to replace the motor, the governor inside the cab and the switch witch tells me its a wire problem. i have power in the motor area and no power from that point to the inside of the car as far as the wires go. what do i do. i have been trying to figure this out for weeks now and am lost.
Oct 28, 2008 at 9:28 PM
BMRFIXIT
  • 19,053 POSTS
start with the fuses
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic_41.jpg
Oct 28, 2008 at 9:44 PM
GRUMPYNETTA
  • 4 POSTS
the fuses were the first thing i changed there are all new fuses in the car
Oct 28, 2008 at 9:48 PM
BMRFIXIT
  • 19,053 POSTS
What I meant is start with the fuse checking the power
do u have power at the fuse then move on to the next following the wiring diagram
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 29, 2008 at 5:50 AM
GRUMPYNETTA
  • 4 POSTS
wher do i find the diagram you sent in the first reply?
Oct 30, 2008 at 9:34 PM
BMRFIXIT
  • 19,053 POSTS
I can e mail it
just let me know where
Oct 30, 2008 at 9:44 PM
GRUMPYNETTA
  • 4 POSTS
my email is [email protected] and thank you. Also how do i check my ground? i am a female trying to fix her own car and having a rough time doing so.
Oct 30, 2008 at 10:08 PM
BMRFIXIT
  • 19,053 POSTS
EMAIL WAS SENT need to use a 12 volt test light know if you are to test the ground place the clips on a power (B+) when u touch ground with the test light it should lights up if not then bad ground switch the clips to a ground (B-) check for power light should light up where you have power start with the fuses check for power
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_24.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_16.jpg
Oct 31, 2008 at 6:42 AM
ATRIUUM
  • 4 POSTS
was the above problem ever resolved?
Dec 3, 2008 at 2:35 PM
ATRIUUM
  • 4 POSTS
if you could please send me the wiring diagrams for the wiper system I'd appreciate it. eunumus(at)yahoo(dot)com THANK YOU in ADVANCE!
Dec 3, 2008 at 3:19 PM
BMRFIXIT
  • 19,053 POSTS
what do you have for car is it the same
are u looking for the same info as above
Dec 3, 2008 at 4:26 PM
ATRIUUM
  • 4 POSTS
same car, same problem
Dec 3, 2008 at 5:29 PM
BMRFIXIT
  • 19,053 POSTS
ok let me try and email you the wiring diagram
let me know if and when u get it
Dec 3, 2008 at 6:45 PM
