Hello and thanks for donating
Disconnect the negative battery cable.
Make sure the headlight switch and the headlight time delay switch (if equipped) are in the OFF position.
Use snapring pliers to spread the retainer.
Remove the headlight electrical connector from the headlight bulb and retainer by grasping the wires firmly, then snapping the connector rearward.
Remove the parking lamp miniature bulb and connector.
Remove the three retainers holding the headlight to the radiator grille opening panel reinforcement, then remove the headlight.
To install:
Install the headlight and secure using the three retainers.
Install the parking lamp miniature bulb and connector.
Engage the headlight electrical connector by pushing the connector until it snaps into position.
Connect the negative battery cable, then turn on the headlights to check for proper operation and aim if necessary.
Sep 17, 2010 at 12:50 PM
