Hello,my question is about a 93 ford taurus 3.0 with 160,000 miles.The problem originally started with the check engine light coming on.Then it went down hill and basically it smokes black and really puts out a black cloud when you get on the pedal hard and does not want to idle.Originally I read the codes and it said the EGR was bad so i replaced the EGR.Now to make a long story short i have since replaced both o2 sensors the fuel pressure regulator,all new fuel injectors,air charge temperature sensor,spark plugs rotor and cap.I am at a loss on why it is dumping so much fuel into the motor,it turns all the plugs black .I would appreciate any advice anyone has to share.Thanks much Dave in WI
Jul 4, 2006 at 5:39 PM
