1992 Ford Taurus wipers
1992 FORD TAURUS
FYRFYTRNMI
Electrical problem
1992 Ford Taurus 6 cyl Front Wheel Drive Automatic
My wipers stopped working. I checked the fuse obviously and then checked for power at the motor. This car has the 2 plug motor. The 3 wire plug has power when the switch is on. The 4 wire plug has power only to the green wire. I tried jumping with a hot wire and the motor still would not work. I replaced the motor and it still doesn't work with the switch but does work when i jump it. What could be the cause of it not working? Are there relays? What wires should have power?
Jan 23, 2010 at 4:59 PM
BMRFIXIT
  • 19,053 POSTS
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_641.jpg
Jan 24, 2010 at 6:49 PM
