1992 Ford Taurus white smoke
1992 FORD TAURUS
TTWNA
  • 10 POSTS
Engine Mechanical problem
1992 Ford Taurus 6 cyl Automatic
I drove a total of 4 blocks when I returned I seen white smoke coming up by the windshield on the passenger side of the car.
May 26, 2008 at 12:35 AM
When you open the hood what did you see? I need the color of the fluid that is leaking
May 26, 2008 at 12:40 AM
TTWNA
  • 10 POSTS
well its night time but i did pop the hood I had to open the door get a flash light thaen I popped the hood by then the smoke was gone i have to go somewhere in the morning I will know more then
May 26, 2008 at 1:01 AM
TTWNA
  • 10 POSTS
i HAVE BEEN TRYING TO UPLOAD A PICTURE TO SHOW U WHERE THE SMOKE IS COMING FROM BUT IT WONT GO THROUGH IS THERE ANY OTHERE WAY FOR ME TO SEND A PICTURE 2 U
May 27, 2008 at 9:12 PM
Is it power steering fluid, engine oil, transmission fluid,antifreeze, brake fluid?
May 28, 2008 at 5:26 AM
TTWNA
  • 10 POSTS
unsure there is just white smoke coming from the engine it appears to be coming from underneath
May 28, 2008 at 10:46 AM
Its either the oil pan or the valve cover gasket leaking and dripping on the exhaust causing the smoke.
May 28, 2008 at 1:39 PM
TTWNA
  • 10 POSTS
is there anything I can do to fix this? will it damage my car?
May 28, 2008 at 3:08 PM
Try tightening the valve and oil pan covers and see what happens-
May 28, 2008 at 3:38 PM
TTWNA
  • 10 POSTS
Well I was on my way to pick up my friend so he could look at my car. About 9 miles on the freeway I notice a clanking noise everytime I accelerated. Then my acceleration was almost non existant I had to floor it to get from 55 to 60 thats when I thought I should get off the freeway.After I exited my car died right there at the light on the off ramp luckily it started back up but drove extremly rough and the shaking that it normally does at 65mph it was doing everytime I slowed down or stopped.
( I realize this is a lengthy post and I will redonate:) )
May 29, 2008 at 12:16 AM
Lets do this other than the smoke-have the idle speed control, throttle position sensor and fuel pressure checked-
May 29, 2008 at 12:20 AM
TTWNA
  • 10 POSTS
ok but whats up with the smoke?
May 29, 2008 at 3:56 AM
1992 Ford Taurus white smoke, your origninal question
I'm a lil bit confused here -which one do you want me to fix what's causing the smoke or what's making it not to accelerate and stalling?
May 29, 2008 at 4:39 AM
TTWNA
  • 10 POSTS
are they related? I have only had the car a week found your site and posted the smoke issue then today I had the car clinking, shking, stalling issue which by the way was accompanyed by smoke.
May 29, 2008 at 6:38 AM
Do you have a check engine light?
No its not related have the idle speed control motor and throttle position sensor and EGR valve checked out.
May 29, 2008 at 11:15 AM
