1992 Ford Taurus tail lights
1992 FORD TAURUS
JAMILEE
Electrical problem
1992 Ford Taurus 4 cyl Two Wheel Drive Automatic
My car's tail ligths went out as well as my interior lights in the inside of my car. I thought it was a blow fuse but all of my fuses are OK, is there anything else that would cause the lights to just go out in a car?
Jan 16, 2009 at 3:50 PM
KEVIN12881
  • 336 POSTS
Your car should have at least two fuse boxes. Did you check both? Your headlights should also be on a seperate fuse. Electrical problems are hard to determine over internet. do you know how to use a tester to see if the "hot" side of your fuse box is hot? A wire could have come loose behind the fuse box.
Jan 16, 2009 at 4:06 PM
