Mystery....
Placing the turn signal in the right turn position works properly unless the headlights are turned on. Then the wipers and washers come on. The washers will keep spraying and the wipers will keep moving until either the headlights are turned off or the turn signal switch is turned off.
This happens whenever both the right turn signal and headlights are on at the same time. Doesn't matter which one is turned on first.
The left turn signal operates as it should..
Aug 9, 2008 at 8:08 PM
