1987 Ford Taurus Wipers/Washers come on with a right turn s
1987 FORD TAURUS
147,000 MILES • 6 CYL • FWD • AUTOMATIC
JUSTDON
  • 154 POSTS
Mystery....
Placing the turn signal in the right turn position works properly unless the headlights are turned on. Then the wipers and washers come on. The washers will keep spraying and the wipers will keep moving until either the headlights are turned off or the turn signal switch is turned off.
This happens whenever both the right turn signal and headlights are on at the same time. Doesn't matter which one is turned on first.
The left turn signal operates as it should..
Aug 9, 2008 at 8:08 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like either a problem with the combination switch on the column or the wiring in the column is shorting..HAve seen both problems, need to inspect eh wiring to be sur eit isnt broken/damaged where it goes downt the column, if ok, it is most likely the combo switch
Aug 10, 2008 at 8:24 AM
JUSTDON
  • 154 POSTS
Thanks for the quick response. I'll check all that today. Thanks again.
Aug 10, 2008 at 8:34 AM
2CARPRO JACK
  • 11,533 POSTS
Youre welcome
Aug 11, 2008 at 7:30 AM
JUSTDON
  • 154 POSTS
Jack...
Turned out to be a plug that I found unplugged under the hood. The problems started when I plugged them back together. I'm not sure what it went to but, the problem(s) went away when I unplugged it again.
It's a small grey plug (2 part) that sits behind the right headlight in the area of the horns. I don't know what it operates. Everything else seems to be working fine with it unlugged.
Aug 11, 2008 at 7:35 PM
2CARPRO JACK
  • 11,533 POSTS
could be a ground or something......good find
Aug 26, 2008 at 7:46 AM
