My vehicle had passed a smog test just a few hundred miles ago, but then was not driven for about 7 years. Now it is a Gross Polluter. I changed spark plugs, re-set timing, changed oil, cleaned EGR & Oxygen sensor, put fresh fuel in and drove it for a few hundred miles prior to testing. Readings are:
HC NO
15 mph Max112 (285) Max 778 (2198)
25 mph Max 86 (292) Max 717 (2667)
The car runs great, gets good mileage, has lots of power, sounds good, and no codes show up when scanned. Can you tell me what I should check/replace next?
Thank you,
Susan P
HC NO
Thank you,
Susan P
Jun 15, 2008 at 10:41 AM
