I have a 2003 Ford Ranger Supra 4.0L 4WD with 84K miles. There is a water type substance (not oil, leaves no residue nor does it burn) dripping very steadily from two holes on the underside of the muffler. I have checked all fluid levels, and all are normal (including coolant, but I had an oil change today so I dont know if it was low). About two months ago I had the rear main seal fixed, however I am told there is still some kind of leak (seaping) near the rear main seal still each time I have had the oil changed. There is no water on the dip stick for the oil (then again I dont know how I would really tell). I am very lost, any ideas on what it might be, is it safe to drive around? If it is safe is there any thing I should monitor so I do not do any more damage? Thank you-
Nov 25, 2007 at 3:07 AM
