Truck won't heat
FORD RANGER
ERIC15
I recently replaced the thermostat in my 1998 Ford Ranger 4 Cyl. 126,000 Miles. The engine was running cold and now it runs just right. But the heater will not work. I had the control valve replaced a few months ago and I think the guy may have messed it up. Where is the heater control valve on this thing? Do you think that's the problem?
Apr 10, 2007 at 4:45 PM
BOOTDOG
  • 665 POSTS
the valve is located in line with the heater hoses. try flushing out the heater core. remove the heater hoses going to the firewall a gently run water through the core till it runs clear.
Apr 10, 2007 at 8:10 PM
