Screeching noise
FORD RANGER
BENNYSALFORD
I have a 2001 Ranger double cab XLT 4X4. 2.5 litre turbo diesel. Approx 85,000 miles on the clock.It has begun to make a screeching noise which rises and falls in pitch with the engine speed and seems to go when in 4th or 5th gear. I rarely use my A/C. It doesn't get any worse in the cold or heat and can start when I first start the truck or start 5 mins into a journey. I changed the turbo this year, so don't suspect that. Belts look fine, but then I'm no mechanic. Had a mechanic look over it-he says major strip down to find source or wait till it breaks!
Oct 10, 2007 at 9:17 AM
BLACKOP555
  • 10,386 POSTS
check the airhoses going to the throttle body all the way back to the air filter for cracks make sure hoses are tight.
Oct 12, 2007 at 9:22 AM
