Drive line, 2000 Ford ranger 4X4 off road 4.0l auto 75,000 m
2000 FORD RANGER
SCRATH
When warmed up, leaving from a stop, small bump or sometimes 2 at time off movement. Trans has been serviced and seems to operate properly other than that issue. When it is quite cold, it does not occur until drive line gets warm. Also, truck has 4.10 poss. rears. U joints are ok. Thank You for your time, Sam
Nov 13, 2007 at 8:25 AM
FISHERMAN
  • 937 POSTS
[quote:f0c7099790="taurus4us"]2001 ford taurus SE 3.0V6 automatic.
Immediately After a professional radiator flush I drove about a half mile shut down and returned about 30 minutes later. car would not crank, battery is good, all I get is a "Click, Click when starter is engaged. I was advised that starter is bad. Replaced with a known good starter same result "click, click" when starter in engaged. Rotated crank shaft manually about 4 inches to a full stop, still same result on cranking.[/quote:f0c7099790]
Hello !!
Check the main Positive Cable all the way from the batt. to the starter..
Also check the connectors (both) and clean the bat. terminals be sure that they are making a clean solid contact, check the ground (negative) cable to the chassis and to the engine be sure that it has a good connection..
the "click" its just the solenoid the motor has no power to start.. (or the solenoid its not closing that contact)
you can try to "feed" the positive directly to the starter but first check all the connections.
Let Us Know after you check this..
We`ll wait for you..
Good Luck!
Nov 13, 2007 at 9:20 AM
TAURUS4US
  • 6 POSTS
Appreciate your help...rechecked cable security. negative connector was loose at battery.(duh). up and running again and saved $1100 for possible eng replace..thought eng had locked up.
Nov 13, 2007 at 11:08 AM
FISHERMAN
  • 937 POSTS
[quote:29d9e85413="taurus4us"]Appreciate your help...rechecked cable security. negative connector was loose at battery.(duh). up and running again and saved $1100 for possible eng replace..thought eng had locked up.[/quote:29d9e85413]
Hey That`s great!
Up and running... those words are music for our ears!
I saw that you donate for our site!
We really appreciate that!
Thanks a Lot And good luck!
Nov 13, 2007 at 1:21 PM
