cruise control worked before
FORD RANGER
CHW1
My f200 ford ranger and I had a brake light problem and discovered a broken wire. I mended the wire and know my cruise doesnt work. Any hints?
Aug 21, 2006 at 3:12 PM
MIKEYBDMAN
  • 623 POSTS
[quote:d8559509c3="chw1"]My f200 ford ranger and I had a brake light problem and discovered a broken wire. I mended the wire and know my cruise doesnt work. Any hints?[/quote:d8559509c3]
If you give the make modle year and engine type i can pull a diagram and see if the wire you repaired is connected in any way to the cruise. I do know that the cruise is kicked off by the brake switch. Maybe your switch is bad some way.
Aug 21, 2006 at 4:36 PM
