bank1 and bank2 too lean
FORD RANGER
CLIFF M
  • 4 POSTS
ford ranger 2000 110000 4.0L
hello i am getting a check engine lite on and the code is a
po171
po174
bank1 and bank2 system adaptive fuel too lean
i put 2 cans of sea foom
i put a new air and fuel fliter
i check coolent
the truck seams to run fine it dos not miss no loss of power
this happen last year about the same time
the tempture out side is between 60f and 30f the lite comes on in the moreing most of the time when its 60 and above the lite
does not come on i think it might be fuel pump or straner or
mass airflow sensor
Nov 18, 2007 at 1:16 PM
BLACKOP555
  • 10,386 POSTS
clean the MAF with qd contact cleaner first, if that does not help check the PCV valve and tube connection for deteriation and rotting.
Spray some carb cleaner around upper and lower intake manifolds and see if RPM's change
Nov 18, 2007 at 9:03 PM
CLIFF M
  • 4 POSTS
[quote:0bdaf185c9="blackop555"]clean the MAF with qd contact cleaner first, if that does not help check the PCV valve and tube connection for deteriation and rotting.
Spray some carb cleaner around upper and lower intake manifolds and see if RPM's change[/quote:0bdaf185c9]
hi i tried what you said it still does it. i noticed that when it gets
colder out it comes on (the check engine lite)
ford whats 80.00 to check it and then they will tell me how much
ive all ways worked on my known cars this it driving me nuts
Nov 23, 2007 at 6:57 AM
BLACKOP555
  • 10,386 POSTS
take it in to autovalue they should do it for free.
Nov 23, 2007 at 2:14 PM
