93 Ranger 3.0 Low Range push button 4WD
1993 FORD RANGER
LAVIGNE_MICHAEL
I have a 1993 Ranger with the push button 4WD. It will engage normally and function properly in high range. But Low range will not work......any suggestions would be helpful. Thanks
Michael LaVigne
Aug 7, 2007 at 12:15 PM
FORDTRUCKBUM
  • 19 POSTS
I have the same issue with my 99 Ford Ranger XLT.
I have tried replacing the switch, checking leads and connections in the dash etc but it didn't help.
Aug 27, 2007 at 11:10 AM
FORDTRUCKBUM
  • 19 POSTS
Hope I am not stepping on his toes, it's been 20 days since his posting. I'll reply about mine too if that is ok.
I place it into park, or nuetral and then click from 2W High into 4W low, I can hear the "clunk" as 4W high is engaged and the light comes on the dashboard indicating it is in 4W High. Then I click over to 4W low, no clunk, no light nothing. It stays in 4W high if I went 4W high first, or it stays in 2W High if I tried to skip over 4W high and jump straight to 4W Low.
I've asked several autoshops, and 2 dealerships what it could be and I always get a "dunno" and then a suggestion to drop it off and let them tinker. That usually costs hundreds of dollars w/o a fix... :(
Anything at this point is appreciated.
Aug 27, 2007 at 6:15 PM
FORDTRUCKBUM
  • 19 POSTS
Inexplicably I tried the neutral, with brakes on from 4W high 6 times, the first 5 times it didn't work but the 6th time it did.
No idea why it wouldn't lock in the first 5 times, but it did the 6th and that is ALL I care about. THANK YOU!
Aug 27, 2007 at 7:47 PM
