Apparently i have either a bad air blend control door or an bad air blend control door actuator. I have heat no matter where i set the dial, either hot or cold. No ac except on max ac b/c that setting does not use the air blend control door.
From reserch it looks like this is a widespread problem.
What are the chances of getting Ford to stand behind this repair, i have the standard 3 yr 36xxx mile waranty.
How can I tell if it is the door or the actuator?
Thanks
Thanks
Jan 23, 2010 at 7:36 PM
