Engine Cooling problem
1996 Ford Ranger 6 cyl Automatic 180000 miles
I am trying to remove the clutch hub assembly from the water pump drivebelt hub. A special wrench is supposed to go around the screws/bolts that hold the pulley to the water pump. However, the four screws/bolts are set inward; therefore, the flat wrench does not work. I could probably get a socket wrench on one of the bolts but I doubt holding one bolt would be enough.
I tried using a strap wrench to keep the pulley from rotating but that did not work. I cannot break the hold on the the large nut that holds the clutch to the pulley.
To better understand what I am trying to say, please look at the diagram found in figure 2 (2.9L and 3.0L engines) at the following link:
http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?pageId=0996b43f802c54b9
This diagram shows the bolt going into the top pulley (call it pulley-a). Pulley-a has the 4 screws/bolts that the wrench can lock onto. In the bottom pulley (call it pulley-b) the bolts are inset, which means the wrench cannot lock onto the bolts.
In my truck, the top pulley (call it pulley-1) is small and to the right of the bottom pulley (call it pulley-2). In my truck, the bolt goes into pulley-2.
Problem: Pulley-2 (my truck) looks like pulley-b (diagram). The screws/bolts are inset.
Any advice you can provide will be greatly appreciated. If someone is able to help me, I would gladly make a donation. Unfortunately, I've been seeking online help all day and continue to get the same answers--answers that do not pertain to my vehicle. (Naturally, my truck is not the norm. =[
Thank you again. I look forward to hearing from you.
Feb 21, 2021 at 5:47 PM
(Merged)
