2004 Ford Ranger Troubleshoot
2004 FORD RANGER
95,603 MILES • 6 CYL • 4WD • AUTOMATIC
BIGMERC764
I can be going down the road and my truck just quits running. So far I have relpaced the fuel pump. The fuel filter. The coil Pack, plugs and wires. It still does it. When this happens I plug in the diognostic meter and it gives me a reading of low fuel consumtion. When it quits like this I have to let it set a couple of minutes and it starts again. Some times I have to wait a little longer for it to start.
Apr 4, 2008 at 9:31 PM
2CARPRO JACK
  • 11,533 POSTS
We arent trying to get you for more money Dave, thanks for the donation, helps keep things running around here. Your truck sounds more like ignition than fuel. I would go after the ignition module or possibly the crank angle sensor. Have seen them fail many times on Fords, and they both will work after cooling back down. Next time it dies, verify that there is no spark
Apr 5, 2008 at 8:04 AM
