Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Ranger
Drivetrain
Differential
Axle
Seal
Replace/Remove
The differential axle seal leaks ?
2004 FORD RANGER
125,000 MILES • 6 CYL • 4WD • AUTOMATIC
HJBFREEMAN
MEMBER
1 POST
FOLLOW
the differential axle seal leaks where. what is the procedure to replace this seal?
Feb 3, 2008 at 10:15 AM
CERTIFIED EXPERT
Here are a number of guides that help with this by giving good detail on how to replace the axle seal and bearings if that is needed as well:
https://www.2carpros.com/articles/rear-axle-seal-replacement
Also, below is the process from the manual that will help replace the axle.
Please let us know if you have other questions. Thanks
Jun 2, 2021 at 7:53 PM
