How do you replace a exterior passenger side mirror. I got the replacemnt from the junk yard.
Feb 23, 2008 at 7:46 AM
MASTERTECHTIM
CERTIFIED EXPERT
you must remove the door panel and take out the 3 ten mm nuts holding on the mirror. **sometimes you can get away without taking off the entire panel if there is a access panel at the mirror spot on inside of door.
