2003 Ford Ranger idle surging
2003 FORD RANGER
89,000 MILES • 6 CYL • 2WD • MANUAL
BHOLTERMAN
when comming to a stop the idle will surge between 0 and 1500 rpms,two or three times and then settle in at normal idle. it will repeat this every time when stopping and after engine has come up to operating temp. thank you
Dec 31, 2008 at 9:14 AM
BLACKOP555
  • 10,386 POSTS
clean out your throttle body and iac module, make sure the pintle moves freely.
if not or it binds then you need a new iac module.
Jan 2, 2009 at 10:30 AM
JASON COOK
  • 6 POSTS
It sounds like the problem i had. I changed the idle control valve and fixed the problem.its like 15 or 20 bucks.
Jan 2, 2009 at 4:35 PM
BLACKOP555
  • 10,386 POSTS
check it before you replace it though!
Jan 3, 2009 at 11:55 AM
