2003 Ford Ranger engine squeak
2003 FORD RANGER
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAYMAN650
my engine just started to squeak today. belts are fine. sounds like it is coming from the rear of the engine. ac is not on.
Jan 10, 2010 at 5:56 PM
THere really isn't anything in the engine that would squeak. Are you sure it isn't a belt? If you pour a small amount of water on the belt, does it go away or change? NOTE: If you do this, make sure to protect your eyes.
Jan 12, 2010 at 8:23 AM
JAMES DERICKS
I have a 2003 Ford Ranger, the same problem is hapening to mine. A squeel is coming from the back of the engine. What was it with yours? Did you ever find out? my neighbor says it may be a lifter in the engine. Hope you found the problem, please let me know.
Thanks, Jim
Jan 13, 2010 at 7:13 PM
SMYTHWOOD
1999 RANGER I have same problem. 72k miles
Jan 20, 2010 at 6:55 PM
