I recently changed the transmission fluid and filter. After draining the fluid and removing the pan, there were three small pieces of metal (stainless steel ?) approximately 1/32" in diameter and shaped like a cylinder. They are approximately 1/32" in height. There was also a brass or copper washer (cresent shaped). It appeared to have broken loose from the other half. Before the service, I had no problem with the transmission shifting as well as afterwards. Everything appears normal. Are those pieces that were in the bottom of the pan anything to be concerned about?
Mar 4, 2010 at 1:24 PM
