2002 Ranger coolant
2002 FORD RANGER
AEKANOFF
I have a 2002 Ranger with the 3.0 V6, 5spd manual trans and 36,000 miles. The truck is 2WD. The coolant is brown, and has an oily feel to it, though the engine is not over heating, nor is the oil "milky." Is this simply dirty coolant or do you suppose oil has gotten into the coolant? I see no standing oil in the reservoir. Any ideas? thank you
Sep 1, 2007 at 10:43 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I feel that all you need to do is flush the cooling system and replaced coolant. I would remove the thermostat (fit a new one while your at it) remove top & bottom radiator hoses, and disconnect the heater hoses, give the heater core a good flush out, don't use very high pressure just the garden tap will do. back flush the radiator and the block, when every thing is flowing clean, check and replace any hoses that look swollen, hard, or cracked, and replace coolant with recommended type, start up with heater on, when up to temp turn off and feel that the heater hoses are warm, put the cap on or best to check for leaks with a pressure tester if you can get hold of one, go for a drive and check for leaks, re check coolant level next day when cold.
Good luck
Mark (mhpautos)
Sep 2, 2007 at 1:26 AM
