2002 Ford Ranger TRUCK SQUEALS THEN SPUTTERS AND TRIES TO D
2002 FORD RANGER
114,000 MILES • 6 CYL • 2WD • AUTOMATIC
KDUB5353
I HAVE AN 02 RANGER EDGE 3.0L V6 RECENTLY STARTED HAVING AN ISSUE WHERE I WOULD BE DRIVING THE MOTOR WOULD MAKE A SQUEAL THE SPUTTER AND TRY TO DIE IF I PRESS THE GAS IT WILL KEEP UP WITHOUT DIEING HAS HAPPENED 4 TIMES SINCE I HAD TO REPLACE THE CAM SHAFT POSITION SENSOR ANY HELP WOULD BE MUCH APPRIECIATED.
Feb 3, 2010 at 5:09 PM
SERVICE WRITER
  • 9,123 POSTS
Sounds like something is seizing up.
I assume the dashboard lights up as it is stalling?
Open the hood and carefully inspect the drive belt and each pulley that the belt wraps around. Look for spots in the belt that have wear marks from it slipping. Alos look for tiny rubber fragments or black dust like material that is on a particular component that the belt runs. Focus on waterpump, alternater and especially the air condition compressor. If there is accumulation aroung the a/c compressor, try unpluging the electrical connector to the compressor and drive it like that for a while to see if the symptom is no longer present.
The 3.0 motor is also common for issues with the idler and serpentine belt tensior pullies.
Feb 5, 2010 at 4:42 AM
