2002 Ford Ranger P0733 error code - delay upshifting
2002 FORD RANGER
112,000 MILES • 6 CYL • 2WD • AUTOMATIC
DCRULES
As speed increases, the truck revs vey high before shifting. On the dash panel, the "O/D off" light starts blinking after the the long shift delay. I checked the fluid and the level is within range and there is no burn smell. The OBD II code was P0733 - wrong ratio for third gear. The repair facility stated that there is no third gear and that the transmission needs to be rebuilt. Because this is such a large expense, I decided to get a second evaluation before agreeing. I guess The code was cleared and I drove it to another repair shop. During the drive, the transmission shifted properly through the gears and the "O/D off" light did not blink again. I'm assuming that third gear is ok and wondering if the cause could be a shift solanoid, vehicle speed sensor, or maybe just needing the fluid and filter changed. Fluid and filter have never been changed.
Thank you for providing this very informative site
Jan 7, 2008 at 10:01 PM
2CARPRO JACK
  • 11,533 POSTS
A service would be a good idea.It could very well be a sticky solenoid, did the speedo work properly?Drive it more and see if it commes back.
Jan 8, 2008 at 2:04 PM
