oil pressure sensor location
2002 FORD RANGER
REIDL
trying to find the oil pressure sensor on the engine?
Apr 5, 2009 at 6:35 AM
DAVE H
  • 13,384 POSTS
Oil Pressure Switch (2.3L)On left rear of cylinder head. Oil Pressure Switch (3.0L)On right rear of engine. Oil Pressure Switch (4.0L)On lower left front of engine. OIL PRESSURE SWITCH Removal & Installation Disconnect the battery ground cable.Disconnect the engine control sensor wiring from the oil pressure sensor. Fig. 150: Disconnecting Oil Pressure Sensor Courtesy of FORD MOTOR CO.
https://www.2carpros.com/forum/automotive_pictures/266999_oil_1.jpg
Remove the oil pressure sensor. Fig. 151: Removing Oil Pressure Sensor Courtesy of FORD MOTOR CO.
https://www.2carpros.com/forum/automotive_pictures/266999_oil2_1.jpg
To install, reverse the removal procedure.
Apr 5, 2009 at 8:05 AM
AHAMME
where is the oil sending unit located on a 2002 ranger 3.0
Dec 7, 2020 at 8:28 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
oil pressure switch is on right rear of engine
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_422.jpg
ABRIDGE
where is the location of the oil pressure sensor?
FAIRRACING31
  • 150 POSTS
Passenger side behind cylinder head in the back of the engine block.
https://www.2carpros.com/forum/automotive_pictures/103836_oil_pressure_switch_3_0_2.jpg
EAGLESCT06
I was just told by the Ford dealer that my oil pressure sending unit was bad and that they wanted $100 to repair it so I decided to do it myself. I purchased the part but I cannot find the sending unit anywhere that I have looked on the engine. Can you please explain to me where it is or better yet show me a picture.
Thank you.
3.0L On right rear of engine-see below
https://www.2carpros.com/forum/automotive_pictures/12900_opsu_9.jpg
JEFMBV
In the morning or when the engine is cold my oil pressure gauge is low or not responding until the engine heats up, then it goes to normal pressure. This takes anywhere from 2 to 5 minutes. During this time, I don't hear or feel anything out of the ordinary. What should be done? Is it the oil pump?
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Just be sure to use the correct viscosity motor oil that your truck calls for. When your truck is cold and you are using a heavier weight motor oil it is the thickest when cold. After your engine warms up the oil will thin out and flow better throughout the engine. The correct oil to use will be marked on the oil fill cap. Since you didn't specify which V6 your truck has the 3.0 L uses 5W-20 oil, And the 4.0L uses 5W-30 oil.
This guide can help as well, and I have included the oil sending unit so you can check the connection or replace the sensor.
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
Check out the diagrams (Below). Please let us know what happens. Hope this helps and thanks for using 2CarPros.
JOHNWAYNE
Where is the oil pressure sending unit on a 2000 Ford Ranger 3.0. It is not where people said it would be
Dec 7, 2020 at 8:29 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
The oil sending unit is located at the right rear of the engine. Check out the diagrams (Below). It is labeled "Oil Pressure Switch"
DWAYNE750
where is the oil sending unit on 2000 ford ranger xlt
3.0L on right rear of engine
https://www.2carpros.com/forum/automotive_pictures/12900_oil1_1.jpg
4.0L at lower left front of engine
