2002 Ford Ranger maps sensor
2002 FORD RANGER
92,000 MILES • 4 CYL • 2WD • MANUAL
MPMARTIN
Engine surges when driving in any gear at less than 2000 rpm. No surge after reaching 2000 rpm. Dealer diagnostics do not indicate electrical problem or any codes. New Motorcraft plugs and wiring harness did not correct.
If the maps sensor is not performing, will it generate a "code" to indicate a problem.
May 2, 2009 at 5:53 AM
MERLIN2021
  • 17,250 POSTS
Did they test the fuel pump? How does it perform going up a steep hill?
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
Yes some sensors can be slightly out of spec and not throw out a code.
May 2, 2009 at 6:36 AM
