2002 Ford Ranger Light Problems
2002 FORD RANGER
77,000 MILES • 6 CYL • 2WD • AUTOMATIC
BUDFU1985
I just bought this truck and like an idiot, did not check EVERYTHING. Well, the parking lights, brake lights, dash lights, or fog lights don't work, but the headlights, reverse lights, hazards lights, and signal lights work fine (at least for now). I replaced the parking light bulbs before I knew about the other problems and I checked all of the fuses. I didn't check to see if the right fuse was in the right place because the truck didn't come with a fuse panel diagram. What do you think my problem is?...and thanks!
Nov 21, 2009 at 6:35 AM
JDL
  • 16,098 POSTS
Welcome to the forum, does the highmount brake lite work? Check the feed to and from the brake switch, located, brake pedal support. Lite green wire with red tracer carries voltage to brake switch. When brake switch is activated, solid lite green wire goes hot. Voltage for brake circuit, fuse 13-- 20 amp, in fuse box, behind left side of dash.
Nov 21, 2009 at 4:20 PM
