We just took my girlfriends Ranger in to have the tranny looked at. It was shifting hard at around 45mph almost as though the overdrive was acting up. The shop basically completely rebuilt the tranny costing around $3000 and yet when we picked it up still same problem. I can drive it and cut the OD off just before the problem and it'll do fine til I drop back down to that speed and rpm range. Th OD light occassionlly flashes as well. I've read about an overdrive solenoid and was wondering more about it. The shop is now reverting the problem to be plugs, injector cleaning or fuel pump, however, that would make sense only if it was more consistent issue not just in the "passing gear". And why would I be bale to cut the OD off and not have the problem if it was one of those other things?
Dec 2, 2009 at 5:05 PM
