2001 Ford Ranger fuel pump fuse
2001 FORD RANGER
123,000 MILES • 6 CYL • 4WD • AUTOMATIC
RAMROD007
About 6 months ago the fuel pump started blowing fuses, it was replaced along with filter and pressure regulator. It has started blowing fuses again, would a dirty filter, or another bad pump be the culprit? Or is something else possibly going out or is bad?
Thanks
Feb 7, 2009 at 9:37 PM
BLUELIGHTNIN6
  • 16,542 POSTS
A faulty starter will usually blow the fuel pump fuse, they are on the same circuit. A faulty ignition switch is the second most common culprit for a fuel pump fuse blowing constantly. Remove starter and have it tested.
Thanks for using 2CarPros.com!
Apr 29, 2019 at 5:55 PM
