2001 Ford Ranger clutch slave cylinder
2001 FORD RANGER
85,000 MILES • 4 CYL • 2WD • MANUAL
TOYRKER
leakage inside trans bellhousing. Have removed trans and need to remove hydraulic unit inside bellhousing. leakage is from rubber boot sitting on pilot shaft. How do you remove hydraulic fluid line. From firewall or at trans & how?
Mar 17, 2008 at 11:15 AM
2CARPRO JACK
  • 11,533 POSTS
Where the line plugs into the slave cylinder (bellhousing) is a small ring that you push into the fitting to release it (actually on line from master)
Mar 18, 2008 at 8:07 AM
