Battery not charging??
2001 FORD RANGER
113,000 MILES • 6 CYL • 4WD • AUTOMATIC
SGAMPP01
My speedometer, tachometer, voltage meter stopped working all at once. Then the vehicle died and would not crank starter. I charged the battery and it started, but quit again after a short time. I suspected the alternator so I had the battery and Alt tested. The battery tested good but the alt showed low voltage output, so i put a new one on. Did not change the problem. The alt is not charging the battery and the above mentioned gauges still do not work. The vehicle dies when it has drained all the juice out of the battery. Any thoughts?
Apr 1, 2010 at 12:16 PM
MERLIN2021
  • 17,250 POSTS
Follow the + battery cable to the solenoid, there you will find three "fusible" links, check for power on both sides of all three. If OK Under the hood find the fuse box, this is the power distribution center, and check all fuses and relays there. MAIN vehicle power is supplied from the alternator to this box...
Apr 1, 2010 at 2:05 PM
JUSTIN C
I have had alternator and battery replaced, still with no charge. I have checked wiring for continuing and wires check out good. I have also checked wiring at starter. all fuses ohm and are good. I have searched for a fuse-able link.
have checked all possibilities with no avail. Is there something I am missing?
Dec 10, 2020 at 8:36 AM (Merged)
HMAC300
  • 48,601 POSTS
i am sure you have checked fuses but check to see if you have power on both sides in one in box under hood. there may be a break in the fuse box and or instrument cluster where the resistor is. or a broken wire to one of the leads to alternator.
EXGANGSTER
Battery indicator light came on and then truck would not run. Replaced my alternator which could not be tested because no one knew how! Installed it and ended up purchasing a new battery. after light remained on and drained my charged battery did not work either. Light remains on and charging system does not work. I have no increase in battery voltage when I started my truck. Took alternator back, got another. Again, battery light still on and alternator still not charging. Now I used two batteries that undergo complete voltage drains, forcing me to rotate and recharge them repeatedly day in and day out, as I continue to use my truck out of necessity. I have checked the obvious fuses/relays with voltmeter and they test and function correctly.
Please help.
CARADIODOC
  • 34,306 POSTS
Check for twelve volts on the yellow wire in the three-wire plug on the back of the generator. If that is missing, check for twelve volts on the large output terminal. If voltage is missing at both places, the large 175-amp bolted-in fuse is blown. If it is only missing on the yellow wire, look for the 30-amp charging system fuse.
BUDDY WILSON
i have put in a new battery and 2 new alternators in my truck and still the battery light is on and wont charge my battery when i take them to the part store they test fine dont know what else to do please help!!!
Check the fuse and wiring -remove connector behind alternator turn key on and check for power at the light green and red wire-also see below
https://www.2carpros.com/forum/automotive_pictures/12900_alty_24.jpg
JT6606
Not charging fuse is good no power to excite wire green with red stripe.
Good evening.
That wire is powered by the fuse listed in the diagram I attached.
It then turns on the light bulb on the dash. From there it goes to the alternator.
Check that fuse and let us know.
BRENT WHITE
my alternator was bad so I have replaced my alternator but the battery light will not go off and its not showing a full charge only coming up 1/4 of the way so I wanted to know what else could be the problem
Dec 10, 2020 at 8:37 AM (Merged)
THETOOLMAN
  • 123 POSTS
Have you had the battery checked. Don't forget the connections everything needs to be cleaned and tighten. The battery may be what ruined your alternator one bad cell can cause the alternator to over charge. Go to Auto Zone or Advance and let them test your battery visually inspect your connections.
If this doesn't resolve your issue you may have a blown fusible link.
Good Luck
JOE MARSHALL
Electrical problem 4 cyl Two Wheel Drive Manual 150,xx miles
I have replaced my battery, alternator,cable from alt. to fuse, fuse, ignition switch, and my truck still will not charge the battery. the cables are tight, the fan belt is good. I went through a spell where the system would charge every other time I drove it, but iI could never tell what I did or didnt do. I did a continuity test on the battery cables and they were good. What should I check next?
SATURNTECH9
  • 30,869 POSTS
It sounds like you have a fusible link that is out or a connection problem. Lets test the system by following this guide
and
With the key on you should have power to the yellow and white wire to the alternator and the B+ terminal of the alternator.
Please let us know what you find.
Cheers
MERLIN2021
  • 17,250 POSTS
Here are some instructions from the repair manual. https://www.2carpros.com/articles/how-to-check-a-car-alternator and 1. Unplug harness connector from regulator at rear of generator. Connect ohmmeter between regulator "A" and "F" terminal screws. See Fig. 1 and Fig. 3 . If resistance is not greater than 2.4 ohms, a short in field circuit or a grounded rotor coil is indicated. Replace generator. If resistance is greater than 2.4 ohms, go to next step. 2. Reconnect regulator wiring plug. Connect negative voltmeter lead to ground. Contact positive voltmeter lead to regulator "A" terminal screw. If voltmeter does not indicate battery voltage, repair open or high resistance in "A" circuit wiring. Perform load test after repairs. 3. If battery voltage is indicated at "A" terminal screw, ensure ignition switch is in OFF position. Connect positive voltmeter lead to regulator "F" terminal screw. If battery voltage is present, go to step 4). If battery voltage is not present, replace generator. 4. Turn ignition switch to ON position (engine off). With voltmeter negative lead to ground, contact positive lead of voltmeter to regulator "F" terminal screw. If voltmeter indicates 2 volts or less, go to next step. If voltage is greater than 2 volts, check circuit between "I" terminal and ignition switch. Repair if necessary. See "S" & "I" CIRCUIT TEST . If "I" circuit is okay, replace regulator. Perform LOAD TEST after repair. 5. Start engine and run at 2000 RPM with headlights on. Measure voltage at "B+" terminal of generator and at generator feed wire at starter relay. If voltage readings differ by more than 0.5 volt, repair high resistance or open in wire between "B+" terminal and junction near starter relay. 6. If generator still does not charge sufficiently, connect a jumper wire to regulator "F" terminal screw and ground it to rear housing. If output voltage increases to 13-15 volts, replace regulator. If output voltage does not increase to at least 13 volts, replace generator. "S" & "I" CIRCUIT TEST 1. Unplug regulator 3-wire harness connector. Connect jumper wire from harness "A" terminal to regulator "A" terminal. See Fig. 1 and Fig. 2 . Connect another jumper wire from regulator "F" terminal screw to generator housing. 2. With engine idling, connect voltmeter negative lead to battery ground terminal. Connect voltmeter positive lead first to "S" terminal and then to "I" terminal of regulator harness connector. See Fig. 2 . Voltage at "S" terminal should be about 7 volts and about 14 volts at "I" terminal. If "S" terminal and "I" voltages are okay, replace voltage regulator. , proceed with appropriate testing.
https://www.2carpros.com/forum/automotive_pictures/62217_fig_1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_fig_2_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_fig3_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_wd_4.jpg
Check fuses, ground wires and fusible links at starter solenoid. https://www.2carpros.com/articles/how-to-check-a-car-fuse Let us know
PWILLIA
Electrical problem
1998 Ford Ranger 4 cyl Two Wheel Drive 85000 miles
My 1998 Ranger (4cyl./manual trans) battery light is coming on in the instrum. cluster. I have replaced the battery and the alternator, however the light is still coming on and the voltage gauge needle is 7/8's of the way to the "H" end of the scale. Any other ideas?
Double check connection at the alternator/battery Get the alternator tested the way you described it-the alternator is overcharging the battery and battery can explode. Also test the battery
https://www.2carpros.com/forum/automotive_pictures/12900_alty_65.jpg
PWILLIA
Thanks for the quick reply. Alternator connections are pretty simple, one wire with nut connection and two plug connectors, not sure how I could have it wrong. Very clean connections to battery. Guess I will take it to Advance Auto and have them check it.
2 LINSEY
  • 287 POSTS
We appreciate your donation and look forward to helping you in the future. Thank you
PRORKBA
1998 Ford Ranger
1998 Ford Ranger with just over 30K miles, 6 cyl, 5-speed. Replaced battery three or four years ago due to starting problems. As can be seen by the low milage, the vehicle sits a lot, sometimes for a week or two, often in very cold weather. The replacement battery is doing the same thing: after a few days sitting, it is slow cranking (a few times, it has even been too dead to crank the engine). After repairing an auto security problem today (door unlock problem due to cold solder joint on a transistor in the aftermarket door-lock module - unrelated to the charging issue), a job that took approximately an hour with the engine idling, thought I would check voltages under a variety of conditions (engine not running, engine running, etc.). With engine off, the battery voltage was 12.36. Once started, the voltage at the battery rose to 14.4V, but continued to rise past 14.6V. From what I've read, the alternator should be limited to a 14.5V output. I'm thinking the voltage regulator is not operating correctly. Does anyone concur or have another opinion?
MERLIN2021
  • 17,250 POSTS
NO-LOAD TEST 1. Connect voltmeter positive lead to B+ terminal on generator and negative lead to ground. Start and run engine at 1500 RPM with no electrical load (foot off brake and doors closed). Read voltmeter when voltage stabilizes. This may require waiting a few minutes. Voltage should be 13-15 volts. 2. If voltage increases to proper level, proceed to LOAD TEST. If voltage increases beyond proper level, proceed to OVERCHARGE CONDITION. If there is no voltage increase, proceed to LOW OR NO CHARGE CONDITION.
It's more likely the lack of driving that's the problem, it's recommended to remove the negative cable for long periods of inactivity.
PRORKBA
Thanks much for the quick response! It could very well be that the vehicle just sits too long, too often. I'll start putting some miles on the vehicle and see if that helps. If not, further testing will commence. I was just curious about the engine-running battery voltage (same also measured at the alternator's yellow wire on the three-wire plug) exceeding 14.5V, but you've suggested 15V is not out of the question. It may be a few weeks before we find out if driving it more often (or pulling the negative cable when not in use) helps. Will update then.
Again, thanks for the quick response.
MERLIN2021
  • 17,250 POSTS
OK I'll be around...
MANKNEE
A few months ago the battery light started going on and off, then it just stayed on and my battery would not charge. I have replaced the alternator 2 times, and I think that they get shorted out because the problem still exists.
MASTERTECHTIM
  • 4,750 POSTS
on the alternator you have a plug with one small wire in it. replace this plug. you will notice if you wiggle the plug the light will go on and off, this is very common.
