got 2001 ford ranger wont start found crankshaft pulley bolt loose , there is no key on shaft and engine postion sensor gets input of pulley . the pully has hole in it has threaded hole in cover . so do you install hole in line with peg and then put engine at tds compression to time?
Jan 15, 2008 at 5:16 PM
