2000 Ford Ranger Unknown box
2000 FORD RANGER
59,000 MILES • 6 CYL • 4WD • MANUAL
LARRY1950
OK I dumb! My daughter just bought this truck and lives two hours from us. She called and said this box fell off from the bottom of the truck and was hanging by 2 hoses. She took a picture on her cell phone and sent it to me. For the life of me I can't make out what it is! It says on the box "canister purge line from throttle body". Could you tell me what it is and is it fairly easy to replace?
Jun 21, 2010 at 6:46 PM
It's the charcoal canister. REMOVAL 1.Disconnect the battery ground cable. WARNING: THE EVAP SYSTEM CONTAINS FUEL VAPOR AND CONDENSED FUEL VAPOR. ALTHOUGH NOT PRESENT IN LARGE QUANTITIES, IT STILL PRESENTS THE DANGER OF EXPLOSION OR FIRE. DISCONNECT THE BATTERY GROUND CABLE FROM THE BATTERY TO MINIMIZE THE POSSIBILITY OF AN ELECTRICAL SPARK OCCURRING, POSSIBLY CAUSING A FIRE OR EXPLOSION IF FUEL VAPOR OR LIQUID FUEL IS PRESENT IN THE AREA. FAILURE TO FOLLOW THESE INSTRUCTIONS MAY RESULT IN PERSONAL INJURY.
https://www.2carpros.com/forum/automotive_pictures/12900_c1_5.gif
2.Disconnect the vacuum line.
https://www.2carpros.com/forum/automotive_pictures/12900_c2_4.gif
3.Disconnect the electrical connector.
https://www.2carpros.com/forum/automotive_pictures/12900_c3_3.gif
4.Disconnect the two fuel vapor tubes. 1 Disconnect the EVAP canister purge outlet tube. 2 Disconnect the EVAP return tube.
https://www.2carpros.com/forum/automotive_pictures/12900_c4_4.gif
5.Remove the nuts and valve. INSTALLATION 1.To install, reverse the removal procedure. **Carry out the leak test. For additional information, refer to Evaporative Emission System Leak Test. See: Evaporative Emissions System\Testing and Inspection\Component Tests and General Diagnostics\Evaporative Emission System Leak Test **Carry out the evaporative emission repair verification drive cycle. For additional information, refer to Evaporative Emission Repair Verification Drive Cycle. See: Evaporative Emissions System\Testing and Inspection\Component Tests and General Diagnostics\Evaporative Emission Repair Verification Drive Cycle https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Jun 21, 2010 at 7:56 PM
