the problem is when i go to slow down or stop the engine will rev up and if i put it in gear and slowly let out on the clutch it will stop or return to normal idle. also when i am driving and go to switch gears it stays revved up while switching gears. it doesn't happen all the time but it does happen often. so far i have replaced the throttle position sensor, and the idle air control valve. i was going to see what else you think it could be.
Mar 21, 2010 at 12:47 AM
