power steering fluid type
2000 FORD RANGER
156,000 MILES • 4 CYL • 2WD • AUTOMATIC
What type of power steering fluid is use for a 2000 Ford Ranger?
Sep 27, 2010 at 12:54 PM
Motorcraft Mercon Multi-Purpose (ATF) should be used here is a guide on how to flush the system
https://www.2carpros.com/articles/power-steering-fluid-flush
Sep 27, 2010 at 10:10 PM
PARKERD
on my 1999 Ford Ranger 4x4, have on several occasions experienced violent shaking in the steering, after hitting bumps (just ordinary highway bumps, nothing unusual). A couple of times on the freeway at speeds in excess of 65 mph, the shaking has caused the vehicle to be nearly out of control. One incident caused me to swerve into another lane; luckily no other vehicle there. Ford service folks 'vacuumed the power steering' and it seemed to fix the problem. Less than a month later, the shaking is happening again. Fluids are fine and there doesn't seem to be any air getting into the power steering reservoir. Any help? Incidentally, this is not a new problem. I've had the truck since 2001 and it's always done this. Originally I rarely drove it on the freeway, just country roads and such. I've moved and drive much of the time on the freeway and is now my only vehicle. The problem is definitely worse at higher speeds.
Feb 25, 2019 at 7:40 PM (Merged)
CARADIODOC
  • 34,306 POSTS
Hi parkerd. Welcome to the forum. If a steering damper is used between the steering linkage and the axle, it should be replaced. You can add one too if your truck didn't come with one. Normally if it's needed and is worn out, the shaking will be much worse than you described.
The next thing would be to have the suspension and steering inspected and the alignment checked. In particular, ask to have the "caster" reduced on both wheels. High caster causes reduced wander / better directional stability, but it increases road feel and the tendency for the steering to overshoot past center when returning from turning a corner. That overshooting tendency can also lead to exaggerated response from hitting bumps in the road.
caradiodoc
RATCHETJAW
  • 6 POSTS
i have looked at the power steering pump and all hoses and pump is not leaking. i think i have found the problem it is in the power steering cylinder. the ps fluid is leaking out of the drivers side
If fluid is leaking from the end of the rack and pinion, it needs replaced.
RATCHETJAW
  • 6 POSTS
it is the rack and pinion i pulled the whole front end out and it got replaced along with several other parts thanks for the help
Glad you got it fixed. Let us know if you have questions in the future.
