Have a 2000 Range 4x4r 4.0L SOHC. Runs smooth at both idle and high rpm. But it is throwing codes P0171 and P0174. Freeze frame shows
rpm 1817
load 45%
speed 37
coolant 170°F
STFT1 +4.6%
LTFT1 +10.1%
STFT2 +1.5%
LTFT2 +3.9%
Are these readings outside of PID parameters? I thought the limit was 10.9% on long term fuel trim.
I am also showing:
STFT3 -99.3%
LTFT3 -49.3%
LTFT4 +25.0%
Also shows EVAP MON test sequence incomplete
What are banks 3 and 4?
I understood the bank 1 and bank 2 to be the two sides of the engine and when both P0171 and P0174 appear simultaneously that is it more likely due to a fuel delivery issue or a vaccuum leak both of which would affect all cyclinders.
Thanks in advance for your input.
rpm 1817
load 45%
speed 37
coolant 170°F
STFT1 +4.6%
LTFT1 +10.1%
STFT2 +1.5%
LTFT2 +3.9%
I am also showing:
STFT3 -99.3%
LTFT3 -49.3%
LTFT4 +25.0%
Oct 14, 2010 at 2:16 PM
