had a problem with the heater blower only working on high setting. Began checking the engine compartment fuses- all OK- started the truck and discovered that the alternator was not charging. Replaced the alternator - new one not charging either. rechecked the fuses, all appear good. checked the hot lead on the rear of the alternator-battery voltage present-12volts. I'm sure that I caused the problem by pulling and checking the fuses, but can't find the problem
Thanks
Thanks
Apr 6, 2009 at 6:46 PM
