1999 Ford Ranger Throttle Postion Sensor
1999 FORD RANGER
98,000 MILES • 6 CYL • 2WD • MANUAL
MICHAEL_DELUXE
I have a 99 ford ranger with the V6 3.0 flexfuel engine. It failed smog test due to "Throttle Position Sensor out of range" according the the code they gave me (P1120). Could the fuel filter needing replaced cause this?
Aug 14, 2010 at 11:45 AM
DOCFIXIT
  • 18,828 POSTS
No fuel filter will not correct code states at idle TPS voltage to low check wiring and connection if good replace TPS
Aug 14, 2010 at 1:00 PM
