1999 Ford Ranger starter engaging
1999 FORD RANGER
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
JRUDEDOG
I have a 1999 ford ranger xlt 6 cyl 3.0 I have gone through 4 starters in 3 weeks. The starter engages by itself while I am driving. There is a poping sound followed by grinding from the starter. After loosing 3 I noticed when it happened I would turn off the key, park, and turn on and off the key switch. I noticed that when moved the key to crank the engine. It would start up winding without turning the key all the way After several attempts it would start without a problem. But for how long I did not know. Sometime it would last several days, sometimes five minutes. I notice when the poping sound was there dash lights would flicker on and off. I have replaced the starter switch under the dash, with no improvement. Could this be something to do with the ignition lock and key since I have the anti-theft? Going haywire and engaging the starter?
Feb 28, 2009 at 10:57 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Suspect faulty ignition switch. Faulty switch will engage starter and ruin then rather quickly if gone untreated.
Thanks for using 2CarPros.com!
Feb 28, 2009 at 11:25 PM
JRUDEDOG
I already stated that I replaced the ignition switch!
That did not make a difference.
Mar 1, 2009 at 12:01 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Check the wires that connect to the starter. Also test starter relay.
Mar 1, 2009 at 4:13 AM
